Won’t start, won’t crank
Cold starts and warm up periods are where most engine wear occurs.
If you're not driving it you just idle the thing until it gets warm doing more harm than good.
Likely filling up the exhaust system with moisture as well.
Mine get driven as late as possible driven right before storage and put away at operating temperature.
Cap off the carb and exhaust openings, lift the negative cable and sit for 5 months or more.
Starting periodically over the winter in the northern climate is not a good idea. I have a couple videos of them running as a fix for the winter months.
Knew you were going to say that....
Sorry, gotta disagree. I understand the whole starting not driving and moisture issue. But I believe sitting without starting is more detrimental to the engines and trans than sitting. I believe you should start it and bring it to operating temperature, and place trans in neutral while running to circulate the fluid in it as well. Operating temps burn off most of the moisture, and the starting wear issue...well if in warmer climate it would be started and driven anyway. I also move mine in the driveway a little periodically if I don't want to street drive it, just to keep other soft components soft and moving, bushings shocks etc.
Notice I said "I believe" as not to offend saying my way and your wrong type of comment. The only exception might be stored in a temperature controlled environment in lieu of outside climate changes.
p.s. love your Charger!
Ok, battery showing 12.8 volts, tried jumping the starter solenoid still nothing, starter just clicks
Starter stud to contactor ring is worn / cooked. As Teens we'd crank the stud nut to turn it a bit and get it to hit.... don't forget to unhook the battery before trying such thing !!
View attachment 1971018View attachment 1971019
I put a brand new starter in with the same results as the old starter. I can pull the new starter back out and check this if the new battery doesn’t work.
You want to know what the battery voltage is when you turn the key to crank the engine, or attempt to crank the engine. A defective battery can show good voltage without any load and drop to nothing under load of the starter.
not to mention you should be bench testing any new starter prior to putting it in, say you bought a bad one, easy these days with all the chineezy crapola, then you assume it's good and throw other parts at it. Test the battery-load test, test like previous mention hooked up when attempting to start, eliminate one item at a time, did you attempt to turn the engine over by hand?? did something break/seize?? Test TEST and test some more
I will check tomorrow
Yes I turned the motor over by hand
not an attack on your resolve, a lot of frustration can cause the parts cannon, guilty myself sometimes, threw some ideas out in case overlooked, don't know how many times I was outta gas suspecting fuel pumps etc
To clarify... The turning of the starter motor to CRANK the engine is one thing. The engine actually FIRING the ignition system, starting / attempting to start is another. It's important to have a better definition of your issue. Basically, unless your electrical system has been modified, the heavy gauge battery + lead goes to the stud on the starter relay and then from the stud to starter motor on the heavy + battery lead. Heavy - battery lead ( ground ) should go to engine block and firewall. The starter relay gets it's voltage from the key switch when starter relay is activated. On a separate lead from the starter relay, + voltage is fed to the starters internal solenoid that actually closes the circuit to operate the starter motor.
Knowing what battery voltage is when key is in the start position would be a good..
twecomm,
You make a good point. Questions/problems about cranking are often lacking in detail.
Ok everyone, I tried another battery and it fired right up. I had purchased one of the yellow top reproduction batteries earlier this year I guess it’s no good. Even though it was fully charged it wouldn’t turn the motor over. I’ll charge it up and try a load tester. I previously had a red top reproduction that lasted 6 years. I appreciate everyone’s input.
