X pipe
68Bee
12:46 AM
IN
Anyone have or can point me to the best place to get an X pipe? Looking for my 68 bee with2.5 in coming off stock manifolds and down pipes.
Thanks
Most muffler shops can get them or I know dynomaxx you can buy just the x pipe or even summit might offer just it as well. It also depends on if you want alumized steel or stainless.
Magnaflow has them also.
dynomax, magnaflow, flowmaster, TTI ( best IMO ) summit racing, jegs, Pypes performance also do a nice 2.5" x pipe
The easiest (and least expensive) way to get equalization in your exhaust system would be to hit a local muffler shop and simply have them install an 'H' pipe to your existing head pipes. Don't forget to ask for a slip joint in the center. The separable joint in the 'H' makes it much easier to remove part, or all, of the exhaust if work needs to be done to the car. Fighting the whole thing at once ('X' pipe) can be a bigger pain. To each his own...Just my $0.02.
I had a custom stainless steel system made with an "X" and tailpipes.
There is a guy on CRAIGS LIST OMAHA NE, has a complete set up with muflers for 200.00.
The mufflers are dynomax ultra flow. Guess its a 3 inch system on a 70 Charger. C/L Omaha, 200.00 Sounds like a good deal
This is the TTI 3" system with the X-pipe. It fit great and works good. I use the Ultra-Flow mufflers on it. Ron
