I was right there about ten years ago, good luck to you!
Mine now
That is a hell of a project! I am just saying be prepared for it to be worse then you think it is. To have the filler panel behind the rear window be as rotten as that one is, an awful lot of water has flowed through the bottom of your back window and down around your wheelhouses and hopefully your rear framerails aren't rotting from the inside out. You should replace your front floorpan with a one piece and not worry about saving your tunnel, you are just creating much more work for yourself. My car was in worse shape then yours, so it is not impossible and you will eventually spend no less then 15 to 20K on this when it is all said and done and that is if you do all of the work yourself. Good luck and keep postin'.
