where to place clutch z bar on frame
moparjohnny
6:30 AM
ga
changing to 4 speed on 68 satellite where do you know where to weld the z bar clutch bracket on frame?
You will see an oval hole in the sheet metal inner fender section. If you align the ball stud so it's centered in that hole in the horizontal direction that will be about right. The factory bracket sits on the top of the frame rail and the weld edge that faces the engine lines up flush with the lip on the frame rail.
