1971 ssp steering colum help please
rog_allen
2:29 AM
minnesota
does anyone know if there is a place to get parts for a tilt wheel column in a 1971 ssp?
Took it apart to tighten and locktite the 4 loose bolts in the knuckle that were really loose..
There is a plastic gear track in there that travels up and down when you turn the key switch to start the car
and the very last gear tooth on the track is missing so we need a new gear track ..any info of were to find one ? Or if they will work out of a standard colum ? Thanks guys
Seems to be hard to find parts for those beings that they are pretty rare. The standard column has a totally different ing. switch setup and doesn't have that part your needing. I don't know if any of the late 70's columns wil interchange.
www.tonysparts.com tony probably has the parts you need...give him a shout
hi i coulnd find anything there so i emailed him ...but we may have found a new part threw napa of all places lol
but there's a lots of good mopar stuff there and i added the site to my favorites
thanks you and ill post how it goes
I'm a partsman at NAPA, if you guys need parts from us, let me know, I'd be happy to give fellow Mopar gearheads a good deal on parts...just PM me. I get parts for cost...
i'm a partsman at napa, if you guys need parts from us, let me know, i'd be happy to give fellow mopar gearheads a good deal on parts...just pm me. I get parts for cost...
thanks for the nice offer..i ordered it it will be here tomorow .. Was only $12.00
MY BOY WAS READING SOME CHEVYS ARE THE SAME LIKE YOU SAID.. HE FOUND THIS AND IT LOOKS LIKE THE SAME ONE...AND ITS THE WHOLE SET UP http://napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_6202246_0065932292 HE IS GOING TO NAPA IN THE MORNING AND TRY TO ORDER IT
ILL POST HOW IT TURNS OUT
THANKS FOR THE HELP
OK I ORDERED THE PART THREW NAPA..WILL BE HERE IN THE MORNING ONLY $12.00 ALMOST SOUNDS TO GOOD TO BE TRUE :eek:
SURE HOPE ITS THE SAME , HARD TO REPLACE THIS COLUMN EXPECIALY WITH FACTORY CRUISE CONTROL ON IT TOO.. ..FINGERS CROSSED
Glad to be of help, can you post a pic of what the column looks like in car? Havent seen one in a SSP.
glad to be of help, can you post a pic of what the column looks like in car? Havent seen one in a ssp.
sure after we get it back in...i just got the new steering gear box that should go in first and also its easyer to swap in the clutch peddles with it out..but will add some pictures of it on the bench with new gear in it
These first pictures are of the new gear
NOW HERE IT IS ALL BACK TOGETHER... NOTICE THE KNOB ON MY SIGNAL LEVER IS FACTORY CRUISE CONTROL..
I WANT TO THANK YOU ALL AGAIN FOR YOUR INPUT AND ADVICE AND A SPEACIAL THANKS TO MY 23 YR OLD SON MIKE FOR DOING ALL THE WORK ON IT 4 ME :3gears:
