bbodybeater75
:eusa_think:hi i have a oil pressure problom with my pro, rebuilt mildy built 360 la engine ,has 4000 miles at about 2000 mile range pressure dramaticly droped why is this happening? i pulled pan a replaced oil pump thinking it may have been defective but nothing changed. so now i have pulled engine out of the car
an comenced a serious inspection,started with cam an lifters, cam bearings got a good track an visably look fine an no spining but, on the #3 cam journal bearing is about 0.10s out of the journal would this cause the problom stated? oil viscosity is 10/30 /fram filter/hp/ hp/melling pump tryed 3 diff, types of oil an viscositiy ranges no difference.
oil pressure range cold idle 50/65
oil pressure range hot idle is 5/15 full rev 25
drops 10 at a time between 150 degrees temp an 190 never touching gas whats wrong with my baby rarely beat on it an never overheated???
can somone whos knows or had similar probloms please help???:sSig_thanks:
dont want to wreck this engine i cant afford another rebuild have 8000 in this one allready
