Andrew
440 Mopar w/ stroker crank yielding 502"
.060 over diamond forged aluminum pistons
10.5:1 compression
Edelbrock RPM Perf heads out of box (not ported)
Comp magnum steel roller rockers (rated for 350 lbs open spring pressure??)
.355 rear w/ 4 speed transmision
3500 lb. 70 Coronet R/T
1300 cfm 6 pack carbs/edelbrock alum intake -
Probably comp cam 23-711-9 or 23-712-9 hyd roller. (both about .540 lift)
Mainly street car but would like to get down 1/4 mi. asap.
Any obvious mismatch or suggestions?
10.5:1 compression
