biginch=bigfun
Freshly rebuilt 440 bored 30 over. In about ten minutes of run time at idle the car will climb past 220 degrees!
My set up:
1977 440 w/ fresh 452 heads, whiplash cam 9.5 to 1 cast pistons. Stant 160 therm., aluminum high flow water pump in a stock cast housing, Edelbrock preformer intake w/ a thermoquad 850. stock distributer hooked to a msd blaster coil & 6al. Cast iron factory "headers".
My radiator is a 26" Northern aluminum 3 core cross flow w/ no trans. cooler running through it. The fan is a Vergo electric (don't recall the cfm but it is the largest they sell), hooked to a toggle switch. I have run clutch fan but got the same results.
What i have observed:
new mechanical gauge rises fast & seems that it would continue to if i left it running.
with the cap off coolant is passing through the cores freely.
no hose colapse, top is aluminum & bottom has a spring.
it boils when shut off & the radiator will be low by a couple inches even though there is a recovery bottle.
my plugs look like brand new, no signs of lean conditions yet.
the car will start again while hot.
Another problem that arose that I'm not sure if its related is. First my amp gauge puked out, so I by passed it by moving the wire from the fuseable link side to the alternator post. Then the next day while i had the car running my bulk head had minor smoke! the alternater connection in the bulk head melted the plastic. I was planning to run a new wire from the alt. to the back of the gauge.
I'm sure I've missed pointing out something in my setup but my mind is a little fried after several days of this fun! So i figured i'd ask for help & a fresh set of ideas.
Thanks in advance to all the great peopl on this board!!!
Louis
My set up:
Louis
