- 10:05 PM
- Apr 13, 2012
- Granite Bay CA
Wow... what fun!
Over the last few days, I cut up my 15th and 16th vehicles, both Dodge RVs. I saved the engines from them, both 360 2 barrel motors with less than 75,000 miles. Unfortunatly only one had a slip yoke and neither had a Gear Vendors overdrive!
I had a set of torches here to use, but with my track record of starting unexpected fires, I used the recipricating saw once again. With the first RV, I went through 5 "Lenox" long blades and 4 short ones, plus 2 cutting discs in the Skilsaw. Before I started the 2nd RV, I bought more blades, but since Home Depot stocked Milwalkee blades, thats what I got. MISTAKE! What a pack of crap! They dulled out quicker and bent too easy. I went back to Lowes and got another pack of Lenox blades.
Oh... What are the torque specs for lug nuts on these things? I broke a 1 1/8" socket and a breaker bar tring to remove the lug nuts! My impact gun tops out at 140 lbs. I had to CUT the housing at the spring pads and take EACH dual wheel end to a tire shop so they could shock the nuts with more volume and power.
I've cut up Valiants, Trucks, a Mercedes and a few others. By FAR, the Mercedes was the most brutal. THAT car had double thick steel in all sorts of places! Hard to reach bolts made it seem like the car was built by an army of tiny men.
