- 11:34 PM
- Jan 16, 2011
- NorCal Sierras
RPM's too
Just for general information.... The RPM's, MP, some Indy & other aftermarket aluminum & cast iron heads, especially in the smaller std. port configurations, use the stock size/type, shafts, valve-train & rockers, but your right some heads need, the high dollar offset rockers &/or special stands, springs,locks retainers, seals, long valves & such... forewarning; {with 3/8" push-rods, not sure with 5/16" push-rods} With the Stealths if you go more than a 1.5:1 rocker ratio, you need to grind quite a bit of material, on the outside of the intake ports casting for push-rod interference clearances, "I've been there done that"... Even using 3/8" push-rods, I have run 1.6:1 ratio Super Gold Crane rollers & 1.6:1 Harlen Sharpe rollers & Isky ductile iron M/W type 1.6:1 rockers on Edelbrock RPM's @ near 0.600" gross valve lift, with no grinding for push rod clearances or special offset rockers.... with no fitment hassles, even with the RPM's superior angle plug design, fitment isn't really a issue, many stock 68-70 383/440HP type cast iron manifold, Super Stock CI manifolds & many other 1-7/8" & 2" headers, all fit with no fitment issues on any I've used, TTI, Schumacher Creative Services, Heddman, even some Hooker's, I have heard some people complain about plug wire clearances though, but usually it was on some of the cheapo brand/style of headers...
our Stealth heads use factory type rocker arms and stock diameter shafts, so no special "high-dollar" offset rockers are required. Any rockers that work on a stock Mopar head will work on our heads. This includes roller rockers, or even stock type stamped steel rockers. Heat crossover is blocked off for increased performance. Factory port windows, exhaust and intake manifold locations make sure you can use any "off the shelf" intake manifold and/or exhaust manifold/headers without any fitment hassles or special "spacers" required.![]()
