old tired rebel
- 8:54 AM
- Sep 25, 2009
Thanks LE I plan to take my time there is a lot of rust to remove and repair. This is a true adventure.
Awesome Cliff. Glad to see this here too so I can keep track of it. Are you gonna try to find a power bulge hood for it? Those are hellified.
I would buy a good Mig welder, (not a flux core) if you do not already have one. You can get floor pans, rockers and other sheet metal from ebay relatively cheap. They are not exact reproductions, but they will work good for you. I did that with my 71 Charger. I would bet when you pull your fenders that the firewall and cowl are rusted as well and that it is leaking inside the car. Mine was the same way and would also suspect your torsion bar mounts are rusted as well. Safe T cap has some nice repair panels that work great! I used their frame connectors and leaf spring mounts that was spot on.
I would concentrate on 1 area at a time and not jump from spot to spot on you build. You will see your progress more and less discouragement from it not getting done.
I put an 8-3/4 rear in mine from an E-body. it will bolt on. the perches are 1/2 narrower, but the springs will pull in that little amount. You WILL need to replace the mounts and ubolts to get rid of the ISO-mount leaf spring set-up on your car. If it was me doing your project, I would get the solid body/frame mounts to stiffen up your car.
Best of luck with the project! We all like seeing the progress of everyones projects.
Right on, Rebel! I dig the name "Green Envy", you certainly don't see many green Chargers out there... looking forward to following your progress on the resto, good luck!
Green Envy, meet Avocado Gold:
Put your floors and torsion bar mounts in before welding in the sub-frame connectors in. don't rely only on the frame connectors for your structural support. Make sure that you weld your pans to the frame rails and the inner rockers as closely to the way it was done from the factory. .
wondering....
If the inner and outer rockers have to come out as well, how is that preformed?
Just curious... just in case I run across this same scenario, or it's actually the case here...
john
Wow, You had a good day, looks like Christmas at your shop! Your going right to town on the ole gal.Thanks for the update..![]()
Nice cliff glad to see it all got there
Awesome dude. Good to see it's moving forward.
Hey Old Tired Rebel man. Looks like that project is evolving. Very cool, I love it when a plan comes together. As I have said before I admire your determination to build this ride. The parts look great and it will be real cool assembled.
I think I might be starting to feel that envy stuff you are talking about.LOL
Keep up the great work and your photos are fantastic.
