69Beeper
Hi,
I have a 68 RR with two front frame rails and two different issues....
The weld nut for the RH side front k member bolt broke loose inside the frame rail. The catch is that the stud is still in the nut. Yep, some previous owner torqued it loose and sheered the bolt head off the bolt and broke the weld nut in the process. The rail is perfect otherwise. I thought of windowing out the top or the inner (side) and weld the nut back in, then welding the piece I cut out back into the rail. I also though of drilling two "large spot weld" holes on each side of the bolt hole, then mig welding the weld nut and broken stud back in place (it looks flanged), then tapping out the broken stud using a torch and prayers. Anyone have this experience before?
The LH side front rail has about a 4 inch section of pinhole rot on the sides and bottom of the rail just to the right of the brake line mounting bracket. The corners where the metal makes the "u" look solid. I want to cut patches and replace with new metal butt welded into place and ground smooth for a seamless repair on all three sides while leaving the bent corners intact. The rail is solid otherwise. Anyone have any advice? I've seen pics of folks doing the same with good results.
Just wanted to get any metal magician's perspective or experience who wants to share...
