rumblefish360
Don't put good money into an engine that wasn't designed to produce big HP. Swap it out with a 340. You'll be happier in the end.
Another person with a "I-d-10-T" issue.
Besides the higher compression pistons in which a 318 can be out fitted with easy enough, the 4bbl. carb, intake and the very modest cam size of the OE 340, tell me what is it that is designed into the engines core parts that make it "designed" where the 318 is not.
You sometimes have to use what you have and 340's are not cheap just to buy one that needs rebuilt.
Exactly! I'm all for bigger cubes to make the job easier. However at the price, I'm not on board with this idea and the posters target goal.
After a sonic check of the 318, you could go far with the bore. Less is better for strength, longevity & power concerns.
Use of hard block helps a good bit with high levels of HP & TQ.
