- 12:52 PM
- Apr 13, 2012
- Granite Bay CA
What the heck happened?
I rebuilt the suspension in 2003. New everything: Bushings, ball joints, tie rod ends, idler arm....I went with poly uppers and rubber lower contol arm bushings. The ride was decent. A bit of additional firmness but with 1.0 T bars, a 1.25 solid sway bar and KYB shocks, i didn't expect it to ride like an Imperial.
Recently i had a clunk in the front when braking. I got it in the air and noticed rubber shards peeling out of the lower control arm bushings! They were not soaked in oil. The front end had always been aligned. I run a 275-40-18 tire up front though, so I expect that it may have stressed the bushing more than a stock 14 inch Goodyear polyglas stocker.
Pretty surprising though, to have both wear out so early and at the same rate.
Has anyone else had an early failure like this?
