- 8:40 PM
- Jan 1, 2013
- Mascoutah, Illinois
Sounds great and I like the valve covers ... can you post a better shot of what you have on them? Looks like crossed flags and 440
I'll try to get you a better pic this weekend. Has two flags then 440 then two more flags and says magnum under it. I got the valve covers and matching air cleaner off eBay. They are just some el-cheapos that I thought looked neat
Here is a link to the same set I bought. I swore I got them cheaper but that was a few years ago
http://pages.ebay.com/motors/link/?nav=item.view&id=230838943085
one of those all day jobs that didn't get finished
It was a long day full of colorful language
Well I finally got some time to start wrenching again, decided to install my new rack and pinion conversion today. This turned out to be one of those all day jobs that didn't get finished. First off there is no way to get the old gear box out without dropping the exhaust loosening the header, removing the starter then removing the header. Pain in the rear! So once that was out I had to reinstall header and starter and I tried and tried but couldn't get this rack to bolt up, realized it was hittin a header tube so pull the starter and header back off and use a hammer to crush the header tube for clearance (did this twice) still not enough clearance so I cut that section of the header off. I was then able to bolt the rack up. after that I had to go to work modifying the steering column to bolt up to this rack parts were include to do this but not the quickest task either. So now here I sit rack is in and can steer car but I need to custom fab the header tube that got cut so ill have to figure out something for that and I still need to install the new pump. It was a long day full of colorful language. And on top of all this the tie rods look to be at a relatively extreme angle.
Instructions claim bolts right up with stock manifolds or tti headers obviously not summit headers.
Next weekend I've got a wedding to go to saturday and not sure what ill work on sunday
Looks like they did a decent job. Car is really nice.The car was an automatic from the factory. A previous owner somewhere along the line converted it to a manual. They welded in the shifter hump.
