kp1241
Greetings all. Need some advice. Bought an unassembled 383 that had all machine work done. Had to have crank polished and heads gone through. Block looked really good. Upon assembling all rotating assembly parts I followed the Mopar rebuild big block book step by step using all proper torquing specs. I plastigauged the crank journals and all were withing spec.
Finally, after months and hours of prepping, put the motor in my 69 runner 4 speed and fired her up. Ran at 1800 for a half an hour and noted that the idiot light on the dash for the oil was on. The car runs awesome, very smooth and has a stock exhaust that sounds good. Changed the oil (straight 30 and oil filter) and same thing, stupid idiot light on dash stays on. Put in electric cheapo sending unit to see gauge. At cold I have 40psi (tops) oil pressure, when it warms up it drops to 25 psi, even if you are revving. I am puzzled. I am thinking something in the oil pump which was a used unit but appeared to be in really good shape.
Any thoughts or advice would be greatly appreciated. I don't want to drop the pan as I triple checked the mains before buttoning her up. Doing the windage tray and pan upside down on my back would suck.
Thanks for any help.
