- 2:12 PM
- Jan 1, 2013
- Mascoutah, Illinois
I brought this home this weekend. 13 years old according to info on sticker but only used for a year or so by my brother before he passed, then sat for at least the last 7 years w/o use in an unheated and uncooled garage in Southern IL heat and cold cycles. We have very high humidity
I plugged it in and since it was in the "auto" position it started right up and before it occurred to me I shouldn't run it w/o changing the oil it was on and running. It ran perfecting for about ~ 30 - 60 seconds and built up 20 PSI quickly then I shut it off. It maintained that pressure for a few hours w/o losing pressure / gauge moving then I bled the pressure off and went to open the stop or drain cock and it wouldn't budge. (it may actually already be open ? )
I have no prior experience with maintaining Air compressors
Oil is 10 years old at least
What is best brand / type of compressor oil or other for a unit like this?
The drain cock appears to be stuck and if I force it i'm sure the "handle" or whatever will break loose. I'm going to shoot it with some PB blaster if that's not a bad idea.
I checked out some vids on removing the drain cock and replacing with an elbow, 4-6" of pipe, and ball valve to ease draining moisture. I've been reading that its best to drain the moisture every day (assume only when it's used ? ).
Should I leave the drain open when not in use or just open and drain when I've run it?
I have a NAPA like 1/2 a mile away and AC stuff is expensive but they are well stocked and I have access to some 10 plus-plus year old AC tools that I'll pick up in the next couple weeks.
I've got two, sections of hose, I think ~25 feet, but they are old as the compressor so I don't know if they are any good. The garage is a modern (small) two car.
I will not be painting cars but possibly could wind up using it to paint parts in future. I will be using impact guns, probably getting a small garage type blasting cabinet for small parts, possibly cut off wheel, grinder, etc mainly for mechanical work, probably not for serious body work.
I don't see running lines for air drops around the garage in my future.
Should i get some type of dryer, filter and or water separator system to add on?
Any and all advice and recommendations are welcome.
Here are some photos.
