- 5:23 AM
- Apr 13, 2012
- Granite Bay CA
Its a bit different with the engine in the car and the heads are on the engine.
I feel your pain Greg, but you're almost there...
Is the degree wheel fixed to the hub which is sloppy on the crank snout? If so that sux, as your TDC won't be accurate. Perhaps a bit of shim or a drop of loctite...
From the May 1997 issue of High Performance Mopar - how to check cam timing using nothing more than:
One Feeler Gauge
One Straight Edge
Two 3/8" drive Craftsman 17mm deep sockets
They claim cam timing can be checked in five minutes this way (I guess five minutes once all the tools are out and everything is opened up).
1. Rotate #1 piston to TDC exhaust stroke, make sure you are at the center of dwell.
2. Pull out both lifters for cylinder #1 and replace with the 3/8" drive Craftsman 17mm deep sockets (which are two-thousands shy of the diameter of a Chrysler lifter).
3. Lay a short straightedge across the top of both sockets. If your cam is installed "straight up", there will be no gap between the two sockets in terms of height.
4. If you find the socket in place of the exhaust lifter is higher than the intake, the camshaft is retarded.
5. If you find the socket on intake side higher than exhaust side, this means the cam is advanced.
6. To measure the amount in degrees how much the cam is either advanced or retarded, use the feeler gauge to measure the distance between whichever socket is lower and the straightedge (with the straightedge placed across both sockets).
7. Six thousands of an inch difference in lifter height is equal to one degree of cam timing.
8. Make some measurements and calculations to find out how advanced or retarded the cam timing is.
9. If you want to advance the cam, remove the timing chain (being careful the crankshaft doesn't move), then rotate the camshaft slightly in the direction of engine rotation until you see the socket on the intake side rise higher than the exhaust side.
10. Measure again using the straightedge and feeler gauge (six thousands of an inch = one degree) and choose the correct offset dowel or key.
This method can also be used to check the condition of the cam.
1. Rotate #1 piston to TDC compression
2. Check cylinder #6 to make sure you have the same timing you found when cylinder #1 was on TDC exhaust.
3. If the specs are different, the cam is probably bad.
Disclaimer: I haven't tried this method but it seems easier than using a degree wheel. Just thought it seemed like a cool, easy way to do it and was posting to see if anyone has done it this way or may find it helpful.
I have lots of stainless steel shim stock that I fold over the key and tighten up the fit of the crank socket. Can you find something like that to use?
