'67Satellite
Hey guys, ugly question.
I was reading the new Mopar Action, and inside there's an article called "First Fire". Well it goes on about setting up you engine so it fires instantly, saving you new camshaft and lifters from spinning dry. R. Ehrenberg says, "The bottom line is this, proven, unfortunately, on a regular basis: If your new engine doesn't start virtually instantly, you're done. Or, at least, your cam is."
Is there any truth to that? He says even if you don't wipe a lobe right away, you likely will within a 1000 miles.
This has me a little scared because years ago after I assembled my 440 I couldn't get it to start initially. In fact it took a fair bit of trouble shooting. After a little while, I found a mistake in the wiring that wasn't allowing power to the coil in the "on" position of the key.
So am I toast and in need of a rebuild.... after only about 50 miles?
(on assembly, I used a ton of Comp Cams assembly lube, and Brad Penn break in oil. Once started I was able to run the motor for about 20 minutes at a fast idle.)
