HYRDGOON
- 11:31 PM
- Apr 20, 2013
- Breslau, Ontario, Canada
Hey All,
I'm trying to sort out my cooling options as I'm prepping to swap out a 383 in my 69 RR for a Stroked 440 (522) The rad and opening currently in my car are 22"... which seems to be the logical choice to me right now is to go with Wizard Cooling's 22" application with the Upgraded Core http://wizardcooling.com/125-tube-core-upgrade
Soooo... with this application is the 4-9" low profile electric fan/shroud assembly rated at 2400 cfm enough or should I be doing a shroud and 6 blade fan?
Also what about changing to a 26" rad.... seems to be more trouble than it's worth with the opening for 22" and the battery/tray in the way. Has anyone else run into similar if so what supplier/combination did you go with?
