'67Satellite
- 12:42 PM
- Jun 16, 2011
- Southern California
Just throwing out another idea. . . Have you tried the old "Listening with a stethoscope" trick? Whenever I try to figure out what a noise is, I always start by figuring out if its running in time with the crank, or with the valve train. . . .this sounded like Crank time to me. . . . I no theres no real clicking or anything, but all the more reason. . it seems to be happening all the time.
Anyway, just came to throw out the old "Listen with a screwdriver or stethoscope" trick.
Good luck man. I hate these kinds of issues.
EDIT: By the way, totally subscribed to this, we are ALL gonna learn something from this, so please keep us updated!
I think it's time to drop the pan . oh by the way , is there a windage tray ? It might be rubbing on the crank.
Did you check end play between torque converter face and flex plate when converter is pushed all the way into trans? it should be a minimum of .250 inch. Another way to check is push converter into trans carefully till it locks. Then measure with a straight edge from the mounting lugs how far recessed into trans converter sits. if it is less then this amount then check for bent flex plate. You may have used a big block flex plate on small block. If this turns out ok. then pull oil pan and check thrust bearing face surface for destruction. this can be seen without pulling crank. if the Converter face does not have this free play, it destroys the thurst bearing face. i f you can not get a good look then your going to have to drop the thrust bearing cap. Do you remember if the re builder set the thrust bearing? it is done with a Brass block held on the snout of crank, with one rap of a sledge hammer to seat the thrust surface. A light rap
What comp cam did you use? Is it billet and requires the bronze gear? The sound is similar to a drill spinning.
If its the groove I think you guys are talking about, its normal. About half inch or so from end of shaft?
Did you start engine with trans out of car? If you did and noise is still their then pull cam gear and see if its hitting block. If not then you have to pull intermediate shaft and check for wear and also the broze fitting in block.
Can you turn the motor easily by hand or with a breaker bar ? it really sounds like something is tight or binding when you shut off the motor.
Why are you hearing the starter when you turn it over by hand?Yea, turns over fine by hand. We spun it over with no plugs to see if i could here it at all without the motor running. And all i could really hear was the starter. No grinding like it makes while it's running. I'm pretty much out of ideas. Tonight i'll pull the timing cover back off and check the clearance between the cam gear and the block. If i don't find anything there, i'm pulling the motor as soon as i can get help and checking the bearings.
Not what I expected to be doing. All i've been worried about is getting brakes and interior in this car so i can drive it. The only sure bet i had was the motor and trans because it was fine in the last car. And here we are...
