73runner
Car runs great and starts right up cold in the morning with no problems. I start by giving it gas as per manual .. Twice to the floor (to prime intake and set choke) and hold part way when cranking... Car runs smooth all the way to full warm up some miles later, after it reaches operating temp (180 degrees per thermostat) still not a problem.
However , once it's been at operating temp for a while or after I stop and the engine heat soaks a bit, it will stall if I hit the brakes just before the car stops. rpm drops quickly, vacuum drops, and often as not it will stall or at best run like crap for a few seconds until the problem "clears" and engine goes back to normal.
Engine has about 1900 miles with easy break-in after complete overhaul. Compression at 9.2:1, timing is set at 9 degrees advance, stock thermoquad with 440 main jets. Thermoquad rebuilt with engine exactly to specifications. Distributor and ignition original. Advance (mechanical and vacuum) both appear to be operating correctly. Thermal vacuum and OSAC both bypassed. Vacuum for distributor taken of back of carb. Stock intake and exhaust manifolds.
Any ideas or suggestions welcome.
Thanks in advance for any help
