can i see your small block spark plug wire routing?
ffej
7:25 AM
nw ohio
im finally getting my car back together and looking for good ideas for some of the small details. looking for pics of how you guys routed spark plug wires on a small block with headers. thanks,jeff
not sure if this is what you had in mind
I don't have any pictures at this time to show, so I hope my description is good enough.
On my small block. I custom cut each wire. Running from the spark plug along side the valve cover to the distributor, I keep the wires down low and wrap the around the back of the valve cover under all the carb linkages. Then up to the cap.
Moroso wire looms and brackets hold them in place. 2 of the brackets are used in the center valve cover bolt. The wire loom clip on are both 2 wire. At the rear of the cover, I use one 4 wire loom on a bracket.
The wires furthest from the distributor are routed up top. Wires closest to the distributor are in the free floating looms.
Done in this manor, it keeps the top of the engine and valve covers free and clear to be viewed for a clean naked look.
my biggest area of concern is the rear two on drivers side. in the past ive used 90 degree ones there but the others were straight. im getting new wires and not sure which style to get the headers are new ttis my old ones were the kind that went around the centerlink so i know this affects the style i get
360 factory valve covers and Hooker headers
Here is my 340 with TTI headers, using the stock guides and only had to widen them a bit to handle the 8 mm wires.
here's the other side
Here's mine
dvw what kind of wire looms are you using that looks like what im looking for thanks,jeff
thanks i think im going to get a set of the morosos i like the way they look
