GearAddict
Ok, so I'm sad to say that after buying my 69RR 383 4spd over a year ago, I've finally re-wired the entire car, recreated the interior from scratch and procured and mounted every piece of missing chrome...but I know nothing about the motor. The car was set-up to drag (shallow gears, frame connectors, ext..) but the motor seemed fairly stock (from looks alone).
I've finally flushed out all the bad gas, replaced carb (edlebrock that was on it was un-rebuilable), checked compression, new plugs and checked the dizzy. Now I'm working on getting the engine running reliably.
The car fires up without a problem every time, but has a super choppy idle (shakes the whole car) and only reads 3-5 Hg (the needle dithers between 3-5). I was thinking vacuum leak, but cannot find one unless it is leaking at the manifold... So I started thinking radical cam? The engine smooths out relatively when wound up
Any other quick tips on determining leak or cam (I know it sounds like a stupid question even as I'm typing it), short of pulling the valve covers and measuring lift (or more importantly duration)?
Also, if measuring lift is the answer, is it true valve lift/duration at the valve stem side (post rocker ratio) or at the pushrod side?
anyway, sorry for sounding like such a noob..any help is appreciated.
