451Mopar
We had an engine come to us, built by someone else, to be stroked and rebuilt. It was a .060 over 440, L2355F pistons, Torker II intake, 750 cfm holley, Crane hydraulic roller 230/236 @ .050. .528"/.539" lift, stock RPM cylinder heads. We dyno'd it before we tore it down.
RPM................TQ/HP
3000.............458/261
3500.............497/331
4000.............492/375
4500.............510/437
4700.............512/458
5000.............510/485
5400.............482/496
5500.............468/490
IQ, did you flow the stock heads. Curious what they flow?
Also, In your opinion, how well built and tuned was the engine?
Just curious if the power (or lack of it) was due to the parts combination, or how it was all put together?
Here's my current projected combo, but may change depending on a few factors (stroker is tempting):
446
Shooting for 11.5:1, but will prob end up just over 11:1
Victor heads
Victor intake
Hyd roller. 230/238 @ .050", .606"/.588", 114 LSA
TTI 2"/3.5"
Pump gas, mild idle.
575 hp at 5750rpm
600 lbft or so at 3800 rpm
Not sure what your point was comparing old cars to new cars?
I have a 6.1L Gen III Hemi, and the heads outflow most aftermarket big block heads, so they have a ton of power potential, but I wanted to keep the old school big block in the '69 Coronet R/T convertible. On that car I chose the stealth heads because they have a near stock external look and they flow a bit better than stock iron heads. My '71 Charger has a 500" stroked 400, that uses ported Max Wedge Edelbrock Victor heads, and a custom 0.700+" lift cam, but I have had issues with the cylinder heads center rocker stand breaking on both heads (700+ lb open spring pressure.) I have fixed that, but that's another story.
My first stroker engine , the 451 400 block was built in the late 1980's, and used Brodix B1-B/S heads. At the time the only aluminum head choices were Mopar Stg6, Original Indy 440, Original B1, and the B1-B/S, and the Stage V Hemi Conversion head. I may have left one out, but there was not much choice, and the only one that would bolt up to a stock big block port intake manifold was the B1-B/S (the stage VI had raised ports, I think a RB intake would fit if the heads were on a B block, but spacers were needed for a RB block.) The Indy EZ and Edelbrock heads would come years later.
