Let's Play Identify Those Chrysler Parts (and Happy Friday)
71SandbugCharger
10:49 AM
California
Ok, I've got boxes full of parts. Can you identify these parts?
Thanks!
If we guess correct, do we win the parts as a prize ?
those almost look like early 70's charger?? don't they go near the front bumper off the fender for filler? maybe not, but I sold a set once off a '73 and looked similar to that
maybe the Plymouth as well, but yes you would be correct
here are the 73- 74 charger
AHHHH MAAAANNNN I had the answer too!!!!!!!!!! Lets do another one. This is way more fun than "pull my finger"!!!!!
Prototype of the first 3D glasses??
Here's one. Which one is for a 727 small block? Winner gets my gratitude because I don't have to pull the starter off to check and first opportunity to buy the one I don't need.:headbang:
I'm going for the one on the right. Just threw my carcass under the truck - I can see the pronounced bump around the biggest fixing hole nearest the starter, and the 3 holes from the center to the starter are not aligned.
You can press the THANKS Button now :rolling:
also no torque converter drain plug drain panel as big blocks have
OK...here's one
Homemade single channel amplifier :icon_eek:
