DetSon
I haven't been able to track anyone down in person for a real life test and like an idiot I forgot to ask anyone at the Carlisle show so I guess I have to try and describe it over text.
I have a three finger clutch of unknown make to me, but the housing itself is red and the pressure plate is from Passion Performance out of Darlington SC, which is old apparently.
Before I started "fixing" everything, the clutch was soft, I'd go as far as saying it was sloppy. Bearing's in the Z-bar were shot or missing, throwout bearing squealed, ball studs were oval etc..
So I replaced and greased everything possible and now the clutch is very hard compared to what it was. My problem is I have no frame of reference. This is the only older clutch I've ever pressed. I do know that when I press the clutch I can see the trans moving through the hole in the floor pan for the shifter. Everything's bolted up and torqued. I do not see anything binding, all springs in place. Pressure plate is facing the correct way.The only thing I think could be binding is the ball stud that mounts to the frame. When the bolt is loose the Z-bar tends to sit "naturally". When I tighten that nut down the ball stud moves the Z-bar a bit but we're not talking drastic, but then again that might be all it takes.
Is there anyway to measure that pedal pressure or does anyone want to come press my clutch pedal? haha
Any advice would be appreciated. Thanks
