Let's Play Identify Those Chrysler Parts (and Happy Friday)
I'm going for the one on the right. Just threw my carcass under the truck - I can see the pronounced bump around the biggest fixing hole nearest the starter, and the 3 holes from the center to the starter are not aligned.
You can press the THANKS Button now :rolling:
There is no gratitude large enough to appreciate the sacrificial act of one Mopar brother throwing himself under a truck for a brother in need.:eusa_boohoo: With much humble gratuity we bow and hope that some day , we too may follow in his footsteps, striving to replicate his most sacrificial act. As a Mopar nation we are grateful .:icon_pray:
Obama Care approved pacemaker?
1963 translinear phase diffraction augmentation circuit. Looks like the upgrade version.
.....the truck was stationary at the time :rolling::rolling:
nope, nope, & nope....
What about a pre-production Voltage Regulator?
a transformer / relay something to do with the 66-67 charger EL dash lighting?
winner.....yes, it's the transformer or power pack to light up the dash lights in 66 & 67 Chargers. Early Chryslers has this design also, 60-63 I think. Power pack changes 12v DC to 250+v AC for lighting
Ok, you senior mechanics hold off a bit...
lol I already know what that is
ok , I have one that I seriously don't have a clue, I don't have an FSM for this car
74 charger SE , it mounts behind the dash , about right in center between the ashtray and the glove box
the plastic mount is broken off exposing a hole in it, what is it and what does it do?
Seat belt interlock control. Only found on 74's.
Yes, it can. The oldtimer in the garage I was in, back in '74, used to do it for customers, cause the dealer wouldn't.
Here's one. Which one is for a 727 small block? Winner gets my gratitude because I don't have to pull the starter off to check and first opportunity to buy the one I don't need.:headbang:
Left is small block and right is small block.... the early ones all had a plug the later ones are one piece
this is a big block 727 inspection cover anyway
and it looks like the one on the left is a 727 and the one on right is a 904
