- 10:27 PM
- Mar 10, 2010
- Hanover, Pennslyvania
looks like a 1950's experimental electronic ignition module
A reverb unit?
Homemade single channel amplifier :icon_eek:
A reverb unit?
There is no gratitude large enough to appreciate the sacrificial act of one Mopar brother throwing himself under a truck for a brother in need.:eusa_boohoo: With much humble gratuity we bow and hope that some day , we too may follow in his footsteps, striving to replicate his most sacrificial act. As a Mopar nation we are grateful .:icon_pray:I'm going for the one on the right. Just threw my carcass under the truck - I can see the pronounced bump around the biggest fixing hole nearest the starter, and the 3 holes from the center to the starter are not aligned.
You can press the THANKS Button now :rolling:
Obama Care approved pacemaker?
nope, nope, & nope....
also no torque converter drain plug drain panel as big blocks have
OK...here's one
What about a pre-production Voltage Regulator?
a transformer / relay something to do with the 66-67 charger EL dash lighting?
Ok, you senior mechanics hold off a bit...
lol I already know what that is
ok , I have one that I seriously don't have a clue, I don't have an FSM for this car
74 charger SE , it mounts behind the dash , about right in center between the ashtray and the glove box
the plastic mount is broken off exposing a hole in it, what is it and what does it do?
push button transmission switch?Ok, you senior mechanics hold off a bit...
Seat belt interlock control. Only found on 74's.
It was just a guess too lol.i saw the springsDing Ding!
Here's one. Which one is for a 727 small block? Winner gets my gratitude because I don't have to pull the starter off to check and first opportunity to buy the one I don't need.:headbang:
