Waking up the beast
T
Thanks. I have bungs in place. You told me it should be close, but my engine is sensitive, much like myself.
Sure, only if it's a Sikorsky.
I'll put any name you want on it.
That set up ran pretty dam good on the street in TORK racing 4406brl 's car when I was shotgun
...that moment when you see your orange shift light , and blue and red light in the mirror in 4th gear .
Who is Martin and why do you want to kill him?
probably/maybe too lean,
Have you changed anything for the previous owners set up ??
have you messed with the air fuel screws ??
where the ignition timing set ?? just curious
maybe if it's not actually a vacuum leak
Leaned it out just to try, but did the same thing. Put back the original setup(84 primary an 92 secondary) Tightened intake bolts and seemed better.
Just took off the intake and found the gasket partially torn. Putting a new gasket on now.
Oh yeah, that's more like it.
All loaded and ready to head down to Atco Raceway. Maybe the last time out for the year. Got the victor intake and Holley carb all set. I'll have a full report on Sunday evening.
We got some headwind!
So, the test today didn't go as I had hoped. There was a 30 MPH cross/head wind at the track today. They would only let us go 1/8 mile. Went up for my first time trial and was popping a bit during the burnout. I made half a pass because it was stumbling off the hit. Breaking up pretty badly. I also heard a whistling sound. Got back to the pits and took off the hood. Found a lot of oil sprayed over the engine compartment. Loaded her up on the trailer and drove 2-1/2 hours home. The good news is I had plenty of daylight left to work on the car. I should tell you that the carb was set up fairly rich to begin with. The DA at 10 this morning was -993ft. So I think I needed to be richer. Any way, I got home and took the carb off and doubled up the gasket underneath to see if that fixed the whistle, but it didn't. Took off the intake and the problematic 440 source valley pan and finally threw it away. Put a stock turkey pan with gasket on and that cured the vacuum and the oil leak. Took the car out for a blast up the street and was still breaking up. Went up another 3 sizes on the jets and went for a ride again. Much better, more responsive and feeling like a lot more power, but still breaking up a tiny bit. Put the car away and called it an evening. I'm going in the right direction with the setup. Next weekend I'll hit Island for a test n tune for probably the last time this year and hope to get some real data. I am encouraged though.
