Propwash
- 2:24 PM
- Oct 29, 2009
- Island of Misfit Toys
Alright Fella's.......I don't want to dishonor our Bi-Monthly "What Cam" question, so here we go.
Car: 1971 Dodge Dart
Weight: About 3,000lbs.
Transmission: 833 4 Speed
Rear: 8 3/4 w/3.55 Gears
Brakes: Manual
Motor: 340
-Bored .040
-Comp 10.47 Est.
-Zero Decked pistons/block
-Ported Eddy RPM Perf. AL 63CC Closed Chambered Heads (Quench!...040 Head Gasket), hand porting-not CNC program
-Port Matched DP Eddy Air Gap Intake
-Carb, Guessing 780 VS Quickfuel
-1 7/8 headers
-Hughes 1.5 Roller Rockers
-Dist...VA/MA?
So i'm stuck between a Roller Cam or a Flat Tappet, Either way I'm leaning towards a solid mechanical cam. Roller's are nice with their more aggressive ramps & quick action, but then comes better springs/hardware and heftier costs. Flat's are cheaper, but only come somewhat close in profiles, require more attention (setting valves a bit more/Zinc'd up oil/Lifespan). Costs between the two said and done.........$1000-1200 vs. $400-$600
Anyways.......I'm looking for around 450-475HP out of this engine. I don't mind a lopey idle, and like listed...it's manual brakes, so vacuum is not an issue. This car will be driven with a great majority on street, with maybe an occasional trip to the strip, just for fun. I run a Street/Strip 512 '69 Roadrunner, with Mechanical Advance Dist., Mechanical Secondary Carb and a solid Flat Tappet Comp Xtreme 244/252@.50, .520/.540Lift and 110LSA. The car perform's just fine on the street with an auto. That being said, trying to build/run a street-strip was bit like threading a needle and i'm looking for something that's going to be a little more accommodating.....like having a choke, vacuum advance & secondaries, bit smoother in ramping up and idle and doesn't require such drastic secondary systems in the fuel/oil/air/drivetrain department. Any idea's fella's?
Brakes: Manual
Motor: 340
-Bored .040
-Comp 10.47 Est.
-1 7/8 headers
-Dist...VA/MA?
