Article about Carb sizing correctly
Rocketman
1:21 PM
Kentucky
Guys, I read this article last night that said correct carb selection was simple:
Cubic inches X max RPM divided by 3456 = CFM
Example:
440 X 5800 = 2,552,000/3456 = 738.42 cfm
Has anyone else used this formula and is it standard?
I just ran those numbers on my past combinations and it works out to be very conservative. My guess it's good for street profile motor but not a competition build.
They used the Holley 4150 series for the example
I have a 750 cfm on the set up below and have no issues
edelbrock had a formula they published years back but they don't show it anymore. i thought it was more realistic for a performance engine. i don't pay much attention to the holley formula.
I was looking for Edelbrocks and found this one. Very interesting:
http://www.gtsparkplugs.com/CarbCFMCalc.html
and this one:
http://www.carburetion.com/calc.asp
The first one in the thread says I have 12 cfm to spare and the rest say 50 cfm or more to spare at 5800 rpm.
I guess the best way to tell is to run what it tells you and then run what you have. See how the car reacts on the low end and the high end. If there all saying the same thing then there probably correct.
Measuring the A/F ratio as well as exhaust gas temps would be the way to go, but that's obviously run on a dyno or some added on sensors/gauges. According to the initial link i'm 100CFM+ over, but my A/F and EGT's from dyno don't agree with that. I'd think that would be a pretty basic guide for a street/stock application. Adding more volume capability up top and getting creative with a cam, IMO would seem to throw a wrench in that calculation. Your last two links fall pretty close to what I have. Like others mentioned, one would have to run what they got to see it really unfold. Good luck!
the last two give me 50cfm to spare
edelbrock used to say do the cubic inches/rpm/divided by 1728 thing and then multiply by 110% for single plane intakes and 125% for dual planes. i don't pay any attention to the cfm crap formulas or ratings. ratings are just marketing numbers and formulas are CYA for the novices.
formula assumes alot of diff #'s,like volumetric efficency.it works 4 stock setups,but the #'s change very quickly with even warmed over motors.not even usefull for hot or full race applications.
Every dyno test on Carbs I've seen seem to show engines like a size bigger than the formulas show? I don't think there's such a thing as an accurate carb calculator with all the variables but it will get you in the ball park.
it was about street applications
the guy that built my motor seemed to know his stuff, I was going to buy a new 850 and he said it was overkill. He has three drag cars and one of those has a 700 cfm carb and he wins with it.
That does seem to be the case if you are running at WOT.
Track testing is what I go by and usually end up with more CFM than any calculator says and usually do the same with high performance street cars but that depends on the type of carb too. I like the big TQ's on the street.....
