Me and EJ ended up pulling the motor out of the Dakota to change the motor mounts and make putting the trans back in easier. We get it all bolted together and back in the truck and as we're bolting and plugging things back together EJ breaks the ear off the starter. I'm really not liking this truck right now, LOL. We pushed it off to the side till he can get another starter for it, so back to the Coronet for me
. I decided to remake my body jig and add features I'd really like to have. When Smythe68 built the one I have now I really liked that it came apart in sections. He built the front and rear sections and then connected the center. I want a center section that I can connect a front and back to. I also really liked the body jig on the 521 restorations site and how it located the frame. The only problem with that jig, is that it's designed for a shop as most are, and not for a one car garage with minimal room. So here's my take on a body jig, right now it's only the center section and I still want to make mounts to locate the trans cross member and the rockers. I also have some more bracing to weld in for the uprights.
The top deck is 6 inches from the bottom of the frame so it acts like a datum line. The hard part was welding the uprights in, keeping them level and the measurements square. Lots of tacking, measuring, cutting them back out and retacking till I got it right.
I used 1 inch nuts and bolts just like 521 for the locating holes on the frame but I also incorporated angle iron to locate the frame so if I need to replace a frame rail I'll just have to set it on the jig, double check the measurements, and weld it in place.
When I make the front and rear sections they will attach with 3/4 inch round pegs so everything stays level. I'm also considering trying to make some kind of leveling system so if I wheel the Coronet out of the garage to do work on it I can level the jig and in turn the car will be level. Then I can take it off the leveling jacks to move it back into the garage maximizing the area I can work on the car. I still have to figure out how to do that part.
Music to weld to.
[video]https://youtu.be/nvlTJrNJ5lA[/video]
