Glenwood
- 10:38 AM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Hey guys,
I stumbled upon a 1970 440 that. The motor is in exceptional condition with all of the cylinders showing minimal wear and no rust, considering it was shelved as a spare motor for the last ten years. My dial indicator tells me that the bore and taper are good and is within specs that shouldn't require boring. I'm happy with that as I'd like to reuse the flat top pistons. I'm thinking of removing the pistons and crank, hone the cylinders and put it back together with new stock bearings and a new mild cam.
I have a set of recently rebuilt 906 heads to use and may use the stock dual plane that came with it. The carb is still in question as I have an assortment of 600 holleys and a 750 dblpumper. I'm wondering if this is a reasonable path to take or are there some pitfalls I'm not thinking about. It would be nice to avoid the extra costs of hot tanking and replacing cam bearings, etc., but would the crank need some attention such as polishing? All thoughts are welcome.
