maxwell1
Ok guy's this one doesn't make sense to me. Here are the stats, fresh rebuild first 500 miles no problems
70 GTX 4 speed car big radiator 7 blade w/clutch hub all good, radiator looks good and clean. 180 thermostat (new) yes I even checked opening temp in water on stove.
Now here's the issue Car warms up thermostat opens, can let car idle for 15 minutes temp gauge shows 190 degrees check water temp with thermometer 190 degrees, take car for a highway drive 60-70 mph after 8-10 miles temps starts to rise 220 - 225 degrees , shut car off and you can hear the water just hammering in radiator. This all happen other night, so today did a rad leak down check dropped 1 to 1-1/2 lbs in an hour. Also did a pressure check on each cylinder pumped in 120 lbs in each cylinder no bubbles in radiator. But with car running I get little bubbles in radiator??????????????? Also did this, I removed belts, thermostat, top hose filled motor up with water,started with motor cool no bubbles in thermostat housing as motor warms big bubbles appear in housing HELP please, sorry for long winded post Thanx Max
