Started a new build on my 65 light blue Dodge Coronet
I chased my tail after this string of 8 second passes. It was a great year and I couldn't leave well enough alone.
So in the off season, I decided to raise the ladder bar up .I think I did 2 holes up which caused the car to wheelie out of control. Even though it was a crowd pleaser and I was able to ride the wheelies out. I lost .07-.09 in ET throughout the run and I couldn't find it.
So after looking at past videoes, it came to my attention that I was in fact going up and not out losing ET.
I only figured it out this year in my 65 pymouth where I was going 9.09-9.11 going way up.
I tightened the frontend down and immeditately went to 9.02-9.05.
I was thinking trans. going away, slicks worn out, valve lash adjustment different, O2 readings, and finally I thought I had worn out valve springs. None of them were the case. It was the high wheelies.
The new 604 KB Hemi is now running. Fired right up without any glitches. Just had to ground the electric oil pressure sending unit. 67-68 oil psi cold and shoots up to 75 psi with a stab of the throttle. You can see the video on facebook. Search Christopher Baum.
Snaggle won't be able to see it though.
LMBO !!! using my wife's phone for internet , she is stingy with the data usage.
^^^^^^^ that ^^^^^^
Weird 1st video that ever said private, just fixed it, its now public.
Is this SUPERISISRACER?
SUPERISISRACER,will you be racing Saturday?
Of course I am. I need to widen my points leader over Mark Dimarjo
I think you need a breath-rite strip.
