superbee_68
There are more problems than I thought. These cars really don't like to sit unused, lesson learned. I will try to present the facts as organized as possible:
Full advance is set to 30 degrees, base timing is around 12 degrees
1,000 rpm idle, drops to 900 rpm when the fans kick on
Vacuum at idle ranges from 9 to 11 inches depending on if the electric fans are running
The fuel pressure is set at a constant 8 psi and does not drop when the engine is revved
The fuel level is about slightly less than halfway up the sight window on both fuel bowls
The alternator is a 300 amp high output that is putting out 14.5 volts at idle
I have discovered new problems last night. My 1 year old rebuild on the heater control valve is leaking anti-freeze, oh joy, the exhaust is now rubbing the crossmember near the transmission and vibrates at certain rpms, how the heck does that happen, and the car will not start when its warm. It fired right up last night, I measured everything, let the car warm up completely, then shut it down for a brief moment. Then, the starter would barely turn over the engine, acted like a dead battery. I waited 15 mintues, then it finally started again. I played with it for a few more minutes and shut it down again. The car then started with the bump of the key, at which point I was started to get pissed. I kill the car, go inside, tell the fiance I am going for a test drive, walk back out, and the thing won't start again, same thing, acting like the battery is dead. I wait 15 minutes, fires right up. I go for my test drive, the car will not handle any load whatsoever. Cruising is fine, just cannot get on the throttle at all. Cuts out, pops, sputters, you name it.
I think I either have an intermittent connection going to the starter, or faulty starter.
I need another rebuild on the heater control valve.
I need to visit a muffler shop
I think I am going to pull the carburetor next. It needs to be gone through even if it's not the problem.
I will definitely check the distributor for proper clearance, that's a great tip Kern Dog! I might also try upgrading the distributor to bring on full advance at lower rpm later down the road, but I don't want to change anything else until I figure out this problem. Thanks for the help guys!
