69greenleaf
i got a 69 satellite. Well today i started my car to let it run, warm up and charge the battery. well after a good ten minutes the car was still idleing like the choke was still on at running temperature. to i pulled the air cleaner and found out that the choke was off and doing what i was supposed to. so then i decide that it was just the idle adjustment was off, so i backed it out and backed it out... and backed it out untill it came all the way out... it should die right??? well no... it continued to idle extremely high like the choke was on. i checked the butterfly valves to make sure there was nothing holding them open and i checked the throttle cable to make sure that it wasnt stuck and it was fine. I dont know what is going on with it but it constantly runs at around 1200 rpms and i can not get it to idle any lower.
