68goldrunner
Im having a strange problem with my vintage late 60s early 70s 8000 RPM half sweep Stewart Warner Greenline tachometer in my 1970 F250. I apologize I know it's not Mopar related but I figure the cumulative knowledge in this forum may be able to help solve my issue.
The tach has its original sending unit mounted behind the tach head. The sending unit is simply wired with three wires. A signal from the negative post of the coil, a clean ground straight to the block, and a lamp wire straight to the instrument cluster lighting. I found an original SW wiring diagram for the tach online and wired as stated. My truck is running a stand alone MSD electronic ignition distributor with a MSD coil. I have researched my tach and from the information I found it was designed to work with electronic ignitions.
My problem is when I turn on the headlights the tach jumps exactly 2000 RPM. This problem is consistent every single time the switch is activated. The tach does not jump around and is not sporatic. The tach works perfectly while driving and goes up and down with engine RPM as expected however it's still 2000 RPM higher with the headlights. Turn the headlight switch off and the tach works and reads no problem.
I have checked all the grounds. I have run the tach with and without a resistor in line with the signal wire however the problem persists. I have searched online for some fix to my problem but have not found one. I've been thinking about possibly sending my tach in to be updated or rebuilt however I'm not totally convinced the problem is within the tach or sending unit because it looks brand new.
All suggestions or opinions appreciated. I'm at a dead end and hoping someone as had this problem before.
Thanks,
Brad
Thanks,
Brad
