Little side-tracked, but a lot of progress too . . .
Okay . . . now that I've FINALLY got the transmission figured out - and the bolt in bracket . . . I ended up with this . . .
Now it will work . . . and my engineer friend, after seeing it has given me the "BSH approval"* stamp on it's construction ! ! But the "look" of the bracket was too plain and simple for my liking . . . I wanted it to look "nice" and fit into the Mad Scientist Build . . . so the bracket has gone through some modifications . . .
Here's the starting point . . . ( uh, looks pretty ugly - but give me some tome )
Added some "lightening holes" and welded in some tubes, as well as added a 1/8" strap to the bottom of the bracket for a little more support . . .
Now to get back to my MAG technology ( Mig And Grind ) . . . and get this thing cleaned up . . .
Continue the grinding and the clean up - with the faces and the edges . . .
So that the bracket will now look like this . . . Now . . . that's what I wanted . . . and I'm much happier with the result ! ! !
With the built in drive shaft loop . . . they look pretty good together . . . ( I think so ) . . .
Now I'll need to make a couple more of these to tie into the drive shaft loop, and the rear brace that will be the bolt connection for the rear of my bucket seats . . .
*Oh . . . by the way, my Engineer friend, and myself include, build things to last . . . so we have dubbed them the
BSH approval . . . for Brick Sh*t House ( as in built like a Brick Sh*t House ) . . . LMAO
I'll have to get you a picture with my coffee on the Magnum Force Coffee Table ! ! ! LMAO ! ! !
Thanks USARR . . . get in my way, the little bugger slowed me down for a month ! ! ! But I was determined to NOT let it stop me ! ! !
Determination . . . ARGH ! ! !
Really glad to see you're rolling along with this thing now. I figure the magnum force Kevin member would make a good coffee table!!
wow khan, alot of work right there. looking real good. if there is a will there is a way. like a little trans mount was gonna get in your way. lmao....nice job!!!
