Waking up the beast
Sometimes you overlook the obvious.
I checked through everything when I got the car in the fall. It even ran well the one pass that I made.
Went to the track on Saturday and the car seemed to be idling a bit rough.
The carb wasn't spraying too well so i cleaned it out a little before running it.
Made my first pass and the car just wouldn't go. i ran 14.0 @68 mph. I lifted :)
Back in the pits, carb still seemed to have a bit of dirt somewhere. cleaned out again and made another pass.
13.20@ 99 I think it was.
Loaded up on the trailer and watched a couple rounds and left.
Sunday morning I decided to dig.
You can see some of what I found.
I rebuilt the carb and took apart the dizzy.
The reluctor is rusty.
The pickup assembly the same.
look at the cap....
I saw that and decided to pull the wires off. I ohm'd the wires and was only able to get a reading on 2 of them and the coil wire. NO reading or continuity on all the other wires.
Look at the cap again.
The only wires that were reading were coil, "2 and "3.
coincides with terminals on the cap.
I was originally blaming the converter, but I see things a bit differently now.
I ordered a new cap, wires, rotor, reluctor and pickup. should be here in a couple days.
Im also sending the original converter out for repair.
That sucks...
does the cell need to be leaned out too ?
dirt in the fuel ?, getting past your filters ? don't see how really
or is it all sediment oxidation corrosion crap in the carbs ?
That sucks...
I think this fish was swimming in the salt at some point. :)
Is that the 6al-2? I'm using one now as well. Had a problem with the old ignition,slowed the car to 10.4's.
Installed an MSD and went 9.8 when I broke the gas pedal,,,,,,,,,,again
Think I got everything straightened out. Heading out to Island Drag way on Sunday for a nostalgia race. Looking for 8.50. Lmbo
good luck, yeah right 8.50...LOL hopefully not in the 1/8th,
sorry Bob, but you teed it up
your a funny guy...
I certainly hope it does way better this time out, you've earned it...
I see a mid-low 10. something in your near future...
soon to be knocking on the door of the high 9. sec. barrier
First pass out I ran 10.80. Car was loose so I had to peddle it. Next pass was my time shot. Car was better.
