moparmarkk
What track are you going to?  Mark
			Take a couple good pictures of your switch plate setup and post it and tell us about it . It looks great.Finished wiring it up today. Looking good to get it going this weekend, also thank you all for the advice.
10.50 will be NO PROBLEM...I'll be interested to see what you run with your 505.
I also built a 505 but it's also on hold while I wait for the Victor heads to get back from porting.
For my combination I'm looking to see some 10.5 time slips, and anything quicker than that will be bonus.
The combo I've put together is also a 505 but with:
Edelbrock Victor Max Wedge heads - full port, will have before and after flow numbers when done
12.7 CR
274 / 282 @ 050, 672 lift solid roller
Indy Cross Ram with 750 Eddies.
Dynamic 5000 converter
Pro Trans with brake
Dana 4.10
3400 lbs less driver.
I also went with the ultra light crank, aluminum main caps, stud and girdle to help hold it together.
Check it out.
The last picture was taken before engine removal a few months ago.
That sure looks lean to me. Perhaps the pictures are showing it worse than it is? Wonder what your primary jet sizing is and perhaps you have a vacuum leak under the carb? Can't be too much else from my experience. In your vid it sounded good otherwise.Very nice build! When are you thinking on getting out to the track?
Also have an issue. Had to pull the motor today, converter didn't center on the crank correctly and I need to send it back. Plus the girdle is leaking a good amount of oil so I just pulled it all back out so I can fix it right once.
Noticed something weird coming out today... The ports are white as can be... Any thoughts on what could cause this??
12.7 CR
Dana 4.10
Check it out.
MALEX..you have a 10.30 et motor there,,,,no problem...give em hell. good jobI'll be interested to see what you run with your 505.
12.7 CR
Dana 4.10
Check it out.
