How to test water heater valve on 1967 Satellite
Max440
8:40 PM
michigan
How can you test a water heater valve? It is removed from the car. Most everything moves freely however there is a plunger of sorts that is part of the thermostat sensor . It is a little stiff. Also I would assume the rubber seal in the valve itseld is questionable. Anyone rebuild these. Pretty hard to find a replacement
All input is greatly appreciated
$75.00 each They came back looking like new with gaskets and o ring. They were for a 64 Belvedere.
I sent mine from my 67 Charger to JC's. Looks new and work perfectly. http://www.jcauto.com/
