Well, I've had enough of this 440 Mystery Motor
Rebuild what I have or replace the engine for possible peace of mind?
  • Rebuild it - it'll be fine
    Votes: 25 83.3%
  • Replace it!
    Votes: 5 16.7%
  • Total voters
    30
How many more does he have
:rofl:
I reckon that was it.
I just so happened to stumble on his ad right after it went live and immediately texted him, asking for the video of it running.
Next thing I know, we're on the phone with each other, chatting away like we've known each other for years.
Mopar guys are like that. :)
When he offered it to me right then and there, I quickly pointed out that if he let the auction go full term, he'd surely get more than that.
He'd have none of it, though.
Good dude.
I made a quick call to PP to verify coverage "just in case", then asked for an invoice, which he sent that day. I paid immediately and off we went. :)
He's been in daily contact since, updating me the whole way on the packing and shipping.
You mentioned it was a 73?
Take a peek at the pilot bushing? Does it look thinner than a normal one?
Was/is it new?
I have a "secret stash" of the old thinner ones if you need one.
Lots of threads here how to measure depth too.
Was/is it new?
Yeah, I'll have to see.
I might even need one of Ehrenbergs' special ones.
Was/is it new?
Are you the reason the thin one can no longer be found? To think I have been turning the thicker one down to fit.
Maybe..........
I picked them up last year at Chryslers @ Carlisle.
Guy had no idea what they were but knew they were for Mopars.
I actually used the Dakota brg in the last 383 before I found them.:(:(
Maybe..........
Suppose I should measure a crank before I foget you've got them.
Yeah, I could give up one for a member here.
There's a guy in Minnesota I believe making them too, but I think he gets big $$, 20+??
Als Rapid Transit
Standard OD is .940
These are OD .915
Old NAPA 615-1033- discontinued
Ed the 'Blue' is OK, but not anything like the Molson ***!!!! Good luck guy.n DON'T TOUCH THAT NEW MOTOR!!lol.
Who cares? Run the roller bearing in the torque converter pilot, easy.
Yeah, that's what I was referring to as the "Ehrenberg" one - Rick sells those roller ones just for that.
Well gentlemen...it has arrived. Looks to have survived shipping really well. I'm pleased, the seller did a hell of a job packaging it. I see no signs of damage at all, not even a hint that anything was leaking either.
I snatched that thang off the truck and got it on my supposed 1000 lb. capacity engine stand by myself, so that's all she wrote for me for a day or two, whilst having the flu no less.
Whew.
I figure this probably is the last time I'll go through all this, so the heck with caution.
Now, the questions start:
1. Is that a forged crank I see? I see it's been tapped for a 4 speed and has a bronze bushing in it already, but I expected that since his was a 4 speed also.
2. Is that a "correct" balancer for the crank or do I need to swap on the new one I have from Summit (it's their silver "house brand" one for forged cranks).
3. How would a '73 motor wind up with a steel crank, if it is one?
RV engine maybe?
4. Should I start a new thread for this phase of the project?
The damper on there looks like it's for a forged crank. They are about 1" wide. A 73 block could have been re built with a forged crank. I did my 77 that way. And I think the truck motors had forged cranks. Most of the R/V cranks were cast iron, I believe. They weren't built for high RPM, just low end torque. And yes, I would start a new thread for this new motor, so as not to confuse this one with the old mystery motor. Good luck! I'm anxiously waiting for the latest developments!
