JimKueneman
Placed some of the ducting under the dash. Was rather taxing. I didn't remove the ducting. The previous owner did, so it was trial and error. Got it in though.
Did a few things on the other side of the firewall as well.
Placed the grommets and hoses to the AC/Heating system.
Have a few questions.View attachment 402574That yellow Grommet in the center of the picture has 2 small holes in it. But there's only one vacumn line. Is the 2nd hole for the thermocouple (if that's what the thin, hollow copper tube going to front of heater box is)?
Or does the thermocouple stay inside the car, and the 2nd hole is for some thing else?
I have no idea, mine does not have the second hole and my grommet has the hose perfectly centered....
What do you think went through there? There is a sensor line that goes from the sensor in the heater box to the missing temperature valve that is to the left of the grommet in the firewall. It is a little feature of the system that does not need to be there and the only way to make it work again is buy a NOS value with the sensor and capillary tube ($450....)
