Transplanting 74 440 into a 1960 Windsor that has a 383?
mosquito13
4:01 AM
FLA
I have a opportunity to purchase a 1960 Windsor with a frozen 383, condition of tran unkown besides being there, but the price for cheap and car is complete. Have a (was running when pulled) 440 out of a 74 New Yorker no transmission. Easy switch? K frame, trans.? Also have a complete running 1964 318 poly and pushbutton 727 as a power option.
I say buy the car and install the 440 and have some fun.Its still a big block..But if the 383 is matching numbers I would look into that then.. Love the car though...
Is it early enough to have that goofy crank and trans setup?
Yeah, I think the crank flanges are different, so it won't be an easy swap. Going with a newer 727, I think you'll have to modify the trans mount and say goodbye to the push button shifter. Finding a '62 big block transmission might solve all those problems though.
'59 and '60 Chrysler 383s were a "RB", raised block engine. As far as the crank ??? This engine was later bored out to the 413.
I would do 440/727, I never did it but seen it done. I would definitely first try to free up the 383, if its not full of rodents and doesn't have a rod hanging out of the block, she probably runs good.
One of the cars I regret most for getting rid of, was a 59 sport fury (Not a touch of rust, had some dents, and no headlights), but the car was kept inside for 30 years, had 24K miles on it, 395 golden commando, I found lights for it, I did the body work ALL HAMMER AND LEAD! Painted it, sent out all the chrome ($800 back then lol), the car looked great.
My point is though, the motor was locked up solid, I yanked the intake and it had a bit of rodent residue but nothing crazy, I drained the oil and it was all oil, I filled it with marvel, every hole I could get it into, I even pumped it through the cooling system.
After a little time I went over and gave it a try, broke it free with a bar, then turned it with the starter, washed it out, put a good carb on, plugs n wires, full of gas oil and 12volts, and she started right up, I mean like it was never shut off. It smoked for 15 minutes and man did it run good, tranny leaked a bit at first but even that stopped, I'm not sure if them were the best engines to be honest I haven't seen many 395's, but it moved right along, the tranny sucked but if you guys ever have a chance to look at one closely and play with it, them 59 Plymouth is a nice car, the seats turned to let you out of the car, the interior is a work of art.
I wish I never sold the car, back then I was kind of doing it to fund the other cars, and it seemed so ugly, now that I am older I appreciate it a lot and would love to own one for sunday breakfasts. Plus I got $9500 for it and now its probably worth $50-$75k
I had a point, maybe the motor is good just needs some love.
'60 will have the extended crank flange and an iron torqueflite. the '74 440 will be externally balanced. i see crank flange and balance issues.
Agree he will be best to change motor and tranny for sure, 440/727 transplant is best option IMO, if the 383 wont spin
I agree with Superb Bee, I would do everything I could to get that original 383 going again. Save you a lot of headaches.
Floor plans ,trunk,brakes, no drive shaft... I passed even at 1500.00 . On Sarasota Craig's list. Seller said it just needed a starter.
"just" needs a "starter" - i.e. somebody to "start" all the floor, trunk, brakes repairs it needs...
I always laugh when an ad says "just needs". If that was all it needed, seller would just do it and then write "needs nothing" and be able to ask 5x as much
