 - 2:16 AM
 - Jan 16, 2011
 - NorCal Sierras
Nice as always
Love checking in on the progress Pat. Beautiful work as always
Very cool trick, makes sense and cures the problem of limited space for hammers and dollies. Thanks.The subject of small dings and dents was brought up, so I thought I would post a few pictures of how an old body man showed me an easy technique to work them out if you have access to the other side. Using a spring-loaded center punch with a filed down blunt end.
Start with locating and marking the dent from the backside. Then unscrew the spring-loaded center punch a few turns as to lessen the blow for the first try. It may take two or three strikes to get the panel flush, along with changing the tension on the spring loaded center punch. You may need to move the impact point a 16th of an inch in either direction to work the dent out.
Pat
A question thou. It's there something you guys use to keep the bare metal from flash rusting while you are working with it in bare metal. Here in Louisiana that would rust in, oh it don't know, 82 seconds.
Hi Pat I have read this post from start to finish so far and can't wait to see it completed .Here in Maryland we only deal with high humidity like you have in Louisiana for about two months in the summertime. During the summer months I have a small air conditioning unit which I run and hold the temperature in the shop at about 79°. That keeps the humidity down and makes it reasonably comfortable to work. During the fall and winter months I keep the shop heated and maintain 60° throughout the winter. Also just like Stanton suggested keep the shop closed at all times to help control the humidity.
Thank you
Pat
Pat, I can help teach Road Runner block sanding 201, as I have just completed first block and high fill primer with 80 grit. Starting tomorrow with second block with 150. Just finished 10 hours filling/blocking yesterday on the hood. I know why no one wants to do body work any more. using a 30" block on about everything, and finding there are about no straight lines on the car. I think I have 90 hours in blocking whole car so far (not counting major metal work and filler). The hood, deck lid, fenders, doors are not on the car yet. there is no way I could have done the 40 and 80 grit with parts on the car. I think my arms are stronger than they have been in years.
My wheels and tires should be here in three weeks and I want to have the car "Roll-able" and ready to go to the spray booth (even though I probably wont be ready). I did do the CV3C Forgelines.
Keep up the good work.
Pat T. in Tennessee
