I almost died installing mine by myself. That beast is heavier than you would think!
What's your gear ratio?
The pig is in! I'm getting closer to lowering this car onto it's wheels.
View attachment 409887 View attachment 409888
Lots of fun installing this heavy pig but wasn't as hard as I thought it would be.
UGH . . . I just put the transmission back in my 4x4 daily driver truck . . . still got the bruises from wrestling it up onto the jack so I could get it in place ( made a nice little adaptation to my floor jack and it worked like a champ - installed it by myself )
Here's what I do - maybe this can help you out too ( or a couple friend that want to wrestle it with you )
Add plywood - for full coverage . . .
Then add transmission ( wrestling it was "fun" . . . )
Of course I was on the ground -
Love it, when a game plan comes together. Looking great!
Maybe one of these days, I can spend more time on mine. Bottom of the totum pole stuff.
Well i slid the axles in to check but they seem to butt up against the thrust block with thw right side having about 1/4" to go. I push it in and it springs back. Is that normal? I could bolt it down but I'd have to hold it there to get the nuts started.
If you are using green bearings, you do not use the thrust block!
According to dr diff, only the clutch style thrust buttons have to come out. He told me the block can be left in the cone style I have. I'm starting to doubt it though. I plan to measure it today to see if i can make sense of it.
So, if you take the o-ring off do the axles go in without springing back? The c clip on the outside groove is what the retainer sits on to hold the axle in the tube? Did you put in inner seals in the axle housing? To me it seems if you used the inner seals that the o-ring on the bearing is redundant, unless it is also used to keep the outer race from spinning as well. Just thinking outloud as I have never installed these bearings...Looks like it is to do with the way the oring seats in the housing. I measured both sides and there is approx 1/8" clearance per side so it's not the thrust block. Both orings seem to want to go so far in and then resist. I greased the outer shell and housing before inserting thr first time.
I decided to measure inside the housing ends and they seem to be tapered approx .0075" within about 3/4" from the housing flange. This would explain the resistance of the oring the deeper the bearing is inserted. I sent Cass an email.
That's a good idea, I'll try to remove them and see if they slide in snug without resistance. Cass thinks it is air trapped when sliding the axle in, but that should force out when I tap the axle in with a malet?...it doesn't. I did use inner seals but I think the oring does keep the bearing from spinning.
Doesn't make sense as there is a breather mounted in the top, on the brake block. But I guess you could crack open the diff plug and try.
