383 Head Gasket Recomendations
SgtLee511
3:00 PM
NE TEXAS
Whats the best Head Gasket, Stock Engine. I usually just do the Fel Pro thing, but I wondering if I could find a thinner Gasket accomplishing the same thing.
mancini has a mopar steel shim that's about .015". mr. gasket 1135g is about .020".
Thanks Ill look into it
A while back I bought some MP steel gaskets from the Dodge dealership, that are .015 inch.
For what it is worth: The Fel-pro perm-a-torq's, while nice, dropped the compression a bit too much for my liking since I have the open chambered 452 heads. So I went with the Mopar Performance steel shim head gaskets which compress down to .020. Got them from Summit, coated them with some copper spray and put them on. Only adviso I'd say is that you'll want to re-torq the head bolts after about a 1000 miles or several heat cycles. I've heard of people not doing such and being fine but I had to drop the headers anyway due to exhaust leaks so I just retorqed them. Still running like a champ.
Thanks the whole issue is, I built my 383 back mostly stock. I looked at the original head gaskets on the bird and they appeared to be pretty thin, what i believed to be factory originals most likely. Knowing that a set of Fel Pros would be significantly thicker. I'm trying to squeeze out a bit more compression out of what I built. I'm going to look at both of those products and see whats reasonable. Thanks
No Problems?
Actually I haven't used them yet but plan to in the near future. I don't expect any issues. They're just like the originals that came on our 383's and 440's back in the day. Just a little thinner.
Thats what Im looking for, appreciate ya
I would suggest using something like "Permatex Copper Spray-A-gasket Hi-temp sealant" on them before installing.
I will do that, question I am a 340 Guy, first big block in my lifetime so, i was looking at intake gasket kits, MP has one without the end gaskets, I didnt see a kit with those in it by them, are we just using the RTV sealant on the front and ends, 'Im using the original intake.
The Mopar big blocks don't have intake end gaskets. The metal pan is the intake gasket.
tHATS WHAT i MEAN dUMB TO bIG bLOCKS lol
You don't sound dumb to me. It's just that there is a learning curve we all go through. At least you're asking questions in an attempt to do the job right. In my opinion helping one another is what this forum is about.
I AGREE THATS WHY IM HERE, BUILDING THE ROADRUNNER MY DAD HAD WHEN THEY WERE NEW, I WAS 16 WHEN HE GOT ME MY 340 CAR, 35 YEARS AGO, WOULDNT BUY THE 383 CAR THOUGHT IT WAS TOO FAST FOR ME, TURNED OUT THE 340 WAS NOT SHABBY. 'IM FIFTY NOW AND BUILDING THE BIRD I COULDNT HAVE THEN , THANKS FOR YOUR HELP
