- 5:27 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Trying to make up my mind on this distance. Worked out at 3/4" at the bottom, 1-1/2" at the top. Leave it or shorten the fan extension?
I'm trying "no shroud" first. (useing E free fuel) I've been looking for one though. Trying to find one that fits without much modifying or I'll just fab my own if the temps run too high. I should have stocked up on all the ones that were being sold for $25 a few years ago. Now the prices on the OE ones are ridiculous!Shroud or no shroud???
Anyone ever seen a fan blade stuck in a stock steel hood , when a blade let go ?The guys at HAMB had a thread about this a while back and I remember the radiator shop fellas saying something about "if you aren't leaving flesh on the radiator fins when installing the fan, you're not close enough".
The consensus seemed to be no closer than 3/4" without shroud (enough room to get the fan belt over it when it throws one out in BFE). With shroud, the fan should be positioned 1/3 outside and 2/3 inside the shroud.
Finally, I had a flex fan shatter and take out a radiator many, many moons ago in my daily driver in the early 80's. It was brand name, too, not a cheapy.
I've shied away from them ever since.
Your fan clearance is exactly where I put mine. Works fine. I'm running a stock 7 blade steel fan though. I have seen those flex fans come apart at high RPM. I was able to use an original steel fan shroud after a little adapting to my 22"alumnum radiator and it cools fine. Got a nice glass beeded original shroud off EB for $45.00. View attachment 427212 View attachment 427213
Good Lord, the stories on that thread!Thanks people for all the replies.
I'm returning the Flex-a-lite. I was considering the light weight and added cooling that you get with them but really didn't add in the risk of the blades breaking. I remember hearing about that years ago too. With any fan, they need to be inspected periodically. I even remember replacing a couple factory ones back in the day.
Read this thread when you get the chance. It happened with a old blade that should have been replaced years ago but still an eye opener!
http://www.forabodiesonly.com/mopar...r-be-very-careful-working-on-old-cars.347235/
Thanks for the info, I'll check out the numbers.2947 short hd clutch Hayden, 5718 Flex a lite fan blade, should fit.
